You have the option to print row details similar to table views. Unlike the table view, the row details list the columns below each other (instead of next to each other) and thus provide a clearer breakdown of the entered data for a row.
Print row details.
  1. Move the mouse to the numbering at the beginning of row, which you want to print.
  2. Click the double arrow icon to open the row details.
  3. In this new window, click on the three dots next to the heading.
  4. Select the Print option.
  5. Choose between the Normal and Compact print options and click Print.
  6. The standard print window of your device opens. Here you can make other settings and see a print preview.
  7. Complete the action by pressing Print.
You can also print a row by opening the row details and using the shortcut Ctrl + P use
The Normal and Compact print types differ in both file size and appearance.
  • The Normal pressure looks very similar to the usual display of row details: you see the entries as you would expect.
    Normal pressure.
  • The Compact pressure reduces the white space and packs all information into a table structure.
    Compact print.
