You have read-only access to your data and can no longer edit it? Don’t worry, your data is safe. You have probably only reached your limits available to you in your current SeaTable subscription.
In order to continue to fully edit your data, you will need to switch to a subscription package that grants you more extensive limits than your current subscription. The steps required for this can be found in detail in this help article on upgrading your account .
Alternatively, you can delete part of your data until you fall below your current limits again.
Please also note that your limits may also be reached if you switch your subscription to a smaller subscription package. If the volume of your data exceeds the limits included in the newly booked subscription after switching from Enterprise to Plus or from Plus to Free , you may only have read access to your data. Consequently, they will no longer be able to edit your data until you switch back to a more extensive subscription package or you delete some of your data.
Therefore, before switching to a lower subscription package, please make sure that your data does not exceed the limits of the newly booked package. You will also receive a notice from SeaTable before confirming a subscription change in the team administration.
Note displayed to you before confirming a change to a lower subscription package
