The team administrator has control over which team member is part of which group. Once someone is a member of a group, they usually have read and write permissions to all bases in that group.
Learn all about the possible roles in a group in the article Group members and their permissions.
Change the membership and roles in a group
- Switch to the team administration.
- Click on the Team menu item.
- Select the Groups category.
- Select a group.
- A new window will open. Click on the category Members.
- Select which Roll the members should take in the group. You have the following options:
- None
- Member
- Administrator
- Save your changes by clicking the corresponding button.
Assign groups directly to a new team member
Already when creating a new team member, you can directly add a person to different groups and assign roles to them.
- Click Add Team Member.
- A new window will open. Select the Groups category.
- Here you can select all the groups to which the new member will be added and define his role in the group.
