In SeaTable, recurring actions and actions can be conveniently performed using key combinations. Inserting a new row , displaying the row details or undoing an action - in SeaTable this can be done in a fraction of a second with the right key combination.
By the way, to quickly get an overview of all keyboard shortcuts, you don’t have to keep returning to this web page. You can also find the overview of all keyboard shortcuts directly in SeaTable. Open it with Ctrl ? or by clicking on the question mark icon in the upper right corner.
Shortcuts in SeaTable
| General | |
| Ctrl F | Opens the search function. With ESC close the search field again. |
| Ctrl G | Show next search result. |
| Ctrl Shift G | Show previous search result. |
| Table view | |
| Ctrl ? | Open the overview of available keyboard shortcuts. |
| Ctrl Z | Undo last action. |
| Ctrl Shift Z | Perform last action again. |
| Ctrl ; | Set selected date or time/date field to today. |
| Ctrl P | Print the current view or row details. |
| Ctrl C | Copy a cell or cell selection. |
| Ctrl X | Cut a cell or cell selection. |
| Ctrl L | row lock/unlock (requires an Enterprise subscription). |
| Ctrl V | Paste a cell (if multiple cells are selected, the value will be pasted into all selected cells). |
| Space | Expanding the selected row. |
| PgUp PgDn Old PgUp Old PgDn | Scroll screen (up / down / left / right) |
| Ctrl ↑ Ctrl ↓ Ctrl ← Ctrl → | Scroll to the respective table border (top / bottom / left / right). |
| Shift Enter | Insert a new row under the currently selected cell. |
| Shift Ctrl Enter | Add new row and open the row details. |
| Ctrl ' | Show comment column. |
| Row details | |
| Shift Ctrl , Shift Ctrl . | Go to the next / previous row details. |
| ESC | Closing the row details. |
Notes
- For key combinations it does not matter whether a letter like F is uppercase or lowercase. To press a key combination, you do not have to switch to entering uppercase letters.
- Always press and hold the function key first and then the letter key. For example: To Ctrl + F first hold down the Ctrl and then press once F .
Comparison table German/English keyboard layout
The labeling of function keys and the arrangement of some keys affected in this article are different on a German and an English keyboard. Since the table above is for English keyboards, below is a table comparing affected keys.
For example: If on an English keyboard the key combination Ctrl ; should be pressed, you can use a German keyboard to Ctrl Ö press.
| Key on an English keyboard | Key on a German keyboard |
| Ctrl | Ctrl |
| Shift | ⇑ |
| ; | Ö |
| ' | Ä |
| Space | Space |
| PgUp | Picture↑ |
| PgDn | Image↓ |
