SeaTable allows you to run custom JavaScript and Python scripts in a base. Besides the possibility to write scripts manually in the text field, you have the possibility to import scripts into SeaTable as well as export existing scripts.
Import of a script
  1. In your base, click  in the base header.
  2. Click Import.
Importing a script into your base
  1. Select a .js or .py type script file from your device for import.
  2. The imported script will be automatically saved in SeaTable and added to your existing scripts.
Export of a script
  2. Hover the mouse over the name of your script.
  3. Click on the three dots  .
  4. Click Export.
  5. The selected script will then be downloaded and saved as a file on your device.
Export of a script
