There are several ways to add a new row in SeaTable. You will learn about the different possibilities in this article.
The first option is to click on the plus icon in the numbering column in the lower left corner of your table. This will create a new empty row at the bottom of the table.
Create a new row
The second way to insert a new row is to right-click on a row and select the option Insertrow above/below from the menu. In the small input field you can specify the number of rows added.
rows insert via the context menu
To quickly several new rows you can also use the key combination Shift + Enter use. First click on a row, under which you want to insert new rows . Then hold down the Shift key button and press the Enter keyto quickly add blank rows .
Add new row via shortcut
Furthermore, some plugins of SeaTable offer the option to add new entries. These include the gallery and the Kanban plugin .
You can’t add a new row in a table and you don’t see a plus icon? Then you probably do not have the appropriate permissions in base or View.
For example, you may have been granted read-only rights instead of read-and-write rights in a share. If you do not have the necessary rights, contact the sharing user or an administrator on your team.
