If another user has shared a base with you, you can leave this share. This is possible at any time with just a few clicks via the start page.
Leaving a shared base
- Switch to the SeaTable home page.
- Move the mouse pointer to the base and click the three dots that appear on the right .
- Click Exit Share.
Impact
If you exit a share by yourself in the way described above, you lose access to any data in the shared base. However, any changes you made in base before exiting the share will still be saved in the base.
