SeaTable’s filter function allows you to use filter rules to filter out the desired entries from a table and display only those entries that meet certain criteria. The set filter refers only to the active view.
Filter entries
  1. Select the view in which you want to set a filter.
  2. Click Filter in the view options above the table.
  3. Go to Add filter or Add filter group.
  4. In the first field, select the column for which you want to define a filter rule.
  5. In the middle field, specify the condition according to which the entries are to be filtered.
  6. In the last field, decide which option or value the condition should refer to.
Depending on the column type you want to filter by, the conditions you can select will also adjust.
You have these condition options with a Text column :
Filter text column
You have these condition options with a Single selection column :
Filter single selection column
You have these condition options with a Image column :
Filter image column
You can restore created filters deleteby clicking on the x symbol click.
Removing a filter of a view
You can create one or more filters that further restrict the first condition. Read more about this in the article Linking filter rules with AND and OR.
You can move and rearrange filters by moving the mouse on the Gripping surface, press and hold, pull and release.
Filter entries sort
