In SeaTable you don’t need to be afraid of losing your data. Even accidentally deleted tables - and even individual columns and rows - can be easily restored afterwards via the trash in the base options.
Table recovery
  1. Click Versions in the top right corner of the base options.
  2. Open the trash.
  3. You will now see all tables, rows and columns that have been deleted within this base in the past.
  4. Select the desired table you want to restore and click Restore to the right of the deletion time.
  5. The selected table will then be automatically added back to your base.
When you retrieve a table from the Trash, it is restored exactly as it looked when you deleted it. This includes the following components:
Restoring a deleted link column
SeaTable offers several ways to recover deleted content. So not only deleted tables can be recovered, but also your last changes, old versions or whole bases. The overview article on data recovery in SeaTable will certainly help you.
