SeaTable allows to create any number of API tokens for a base. Therefore, it is recommended to create a separate token for each interface, app or development. These tokens can be deleted or their authorization changed at any time.
You can edit and delete the API tokens either on the home page or, as a team admin, also via team administration.
Available with Team members Team Administrators
On the SeaTable home page, you manage your API tokens each within a base.
  1. Move the mouse over a base.
  2. Click
  3. Expand the Advanced section and select API Tokens.
  4. Edit the existing API tokens with  or delete a token with  and then Delete.
Available with Team Administrators
A team administrator also has the possibility to manage the API tokens of all bases he has access to via the team administration. Switch to the team administration and there to the API & Integrations section. There you will find all API tokens, which you can delete if necessary.
