The duration column is particularly suitable for recording the duration of various events. It can record a period of time to the minute or even to the second. For example, the duration column can be used in conjunction with a date column for recording working hours.
Application example for a duration column
When creating the duration column, you can decide whether you want to raise the duration to the minute or even to the second.
Creating the duration column
Duration column to the minute
Continuous column to the second
