For optimal design of your apps, you should of course test them before publishing. To see your apps as users do, you can preview the current editing status at any time or simply open the apps in normal mode.
Open an app
Basically, you can test your apps at any time by opening them in normal mode.
- Open the base in which you want to test an app.
- Click Apps in the base header.
- Click on the name of the app to open it.
Open the preview in Universal App Builder
You can also view the current status of your app at any time in the editing mode of the App Builder.
- Hover your mouse over the Universal App and click the pencil icon that appears to open it in edit mode.
- Click the eye icon at the top left of the page.
- The app preview will then open in a new window.
