You have built a sophisticated app that you want to use in a similar way for another user group? Then simply copy the existing app and customize the copy as you see fit.
  1. Open the base where you want to copy an existing app.
  2. Click Apps in the base header.
Click apps in the base header
  1. Hover your mouse over the app and click the copy icon that appears  .
Copy apps
  1. The copy of the app opens in edit mode, where you can adjust the settings directly.
