You can perform various operations using the data processing function. You can perform mathematical calculations across all values in a column, as well as correlate values when entries in two different tables are identical.
You can delete already created data processing operations at any time using the view options in your tables.
Deleting a data processing operation
- Open any table where you want to delete a data processing operation.
- Click on the three dots in the view options.
- Click on Data Processing.
- Hover the mouse over the created data processing operation you want to delete and click the trash can icon.
Consequences of deletion
If you delete a data processing operation that has been created, it is irrevocably deleted and consequently cannot be restored. However, the calculated or related values in the results column of your table will still be preserved.
Of course, you can no longer execute a deleted data processing operation, i.e. you can no longer consider entries added to the source column afterwards. However, if you want to work with the data processing operation in your table again at a later time, you can create at any time.
