You can perform various operations using the data processing function. You can perform mathematical calculations across all values in a column, as well as correlate values when entries in two different tables are identical.
You can create data processing operations at any time using the view options in your tables. You simply store the results of an operation in an additional column.
Create a data processing action
  1. Open any table for which you want to create a data processing operation.
  2. Click on the three dots in the view options.
  3. Click Data Processing, and then click Add Data Processing Operation.
  4. Give the operation a name.
  5. Select an operation.
  6. Depending on the operation, define the table, view, source column and result column or the tables and columns to be compared.
  7. Click Save to save the operation and run it later, or Run to start the operation directly.
Definition of the data processing action
Currently, the following operations are available to you:
  • Calculate cumulative values
  • Calculate ranking
  • Calculate changes
  • Calculate percentage
  • Compare and link
  • Compare and copy
  • Transfer user name
There are different requirements for creating a data processing operation depending on the operation.
For mathematical calculations, i.e. for the operations Calculate cumulative values, Calculate ranking, Calculate changes and Calculate percentage, you need at least two number columns in the selected table view. Usually, the source column already exists and is filled with data, whereas you create the result column and fill it with values through the operation.
For the other operations you need partly link columns (compare and link & compare and copy) or text columns (transfer user name).
