In the following article you will learn how to import data from Microsoft Access to SeaTable.
Data import from Microsoft Access
The most important information right at the beginning: A direct import of Microsoft Access files into SeaTable is currently not possible.
However, there is a small detour through which you can still import Access databases into SeaTable. Proceed as follows:
- First, export the required tables from Microsoft Access as CSV files.
- You can then import the CSV files exported from Microsoft Access into SeaTable as usual.
- The steps required to import a CSV file from Microsoft Access are identical to importing any CSV file .
