The columns Creator and Created time are filled automatically by SeaTable and therefore represent special column types. While SeaTable fills the Creator column with the name of the user who created the row, the Created time column records the moment (creation date and time) when the user created the row.
Special features of the two column types
- The automatically entered values in the Creator and Created time columns cannot be edited.
- When creating the two column types, no options are available, except for the column name.
- Only one Creator and Created time column can be created per table. If you try to add another column of the same type, the message “Another column has this column type.” appears.
- For this reason, you cannot duplicate Creator and Created columns and customize their column type.
