You can configure the look, content, and functionality of your web form by customizing the form settings, field settings, and color scheme. The latter requires an Enterprise subscription.
Adding and configuring fields in a web form
  • If your base consists of several tables, you can select the table for which you want to create the form.
  • Drag and drop static elements and table fields into the form or click the plus icon to the right of their names.
  • If you want to insert help texts to fill in the form fields, you can define the font color of the help texts.
  • You can choose between two notification rules: Either no notifications are sent or you specify a recipient (e.g. yourself) who receives a notification when a form is submitted.
  • You have the option to restrict access permissions only to users logged into SeaTable.
  • With one click you can define that all fields should be required mandatory fields that must be filled by users.
  • You can show and hide “Powered by” via a slider.
  • Add a default message that a user will see after submitting the form.
  • After completing the form, you can activate a redirect to a web page (for example, a thank you web page or homepage).
  • With a submission deadline, you limit how long the form link is valid.
Click a field to have more setting options on the right side.
  • You can specify a field name different from the column name to be displayed in the form. In this way it is possible to name the columns in the table completely detached from the web form.
  • In the help text, write down instructions or explanations on how to fill in the respective field.
  • Decide whether the particular field is a required mandatory field or not. If you enable this setting by the slider, users will have to fill in the field to be able to submit the form.
  • Decide whether the respective field should be prefilled with a default value or not. You can activate by another slider that the fillers cannot change this value.
  • Specify whether a field should only be displayed if previous fields meet certain conditions. This allows for more accurate user guidance, as irrelevant fields remain hidden in the filling process.
You can change the order of the fields in the web form as you wish by clicking the six-dot icon  in the right corner of a field and dragging and dropping the field to the desired location.
To remove a field from the form again, click on the trash can icon  at the same place.
Available with Enterprise
Especially for companies and organizations it can be interesting to individualize a web form according to the corporate design.
For this purpose, you can brand your form with your logo.
Change logo in web form
You also have the option to customize the top color bar. To do so, click Color Scheme in the upper right corner next to Settings.
As an alternative to the color bar, you can also add a title image.
Visual customization options in web forms
