In SeaTable, you have the option of adding checkbox columns to your tables. These are ideal for marking tasks as completed, for example - i.e. for an overview of whether rows fulfills a certain yes/no condition. You can therefore make excellent use of checkbox columns for filtering , sorting or grouping .
Create a checkbox column
- Click the [+] icon to the right of the last column of any table.
- Give the column a name.
- Select Checkbox as the column type.
- Decide whether the default value of the column should be empty or checked.
- Confirm with Submit.
Style options of a checkbox column
Don’t like the default green tick? No problem! You have 70 different style options to fill in your checkboxes the way you want.
