Available with Enterprise
Trigger events represent one of the two essential components of automations. The events trigger different types of actions, which you can define individually for each automation. This article provides you with an overview of the different types of trigger events.
In the latest version of SeaTable there are a total of four different trigger events to choose from:
Trigger events currently available
  • Entries meet certain conditions after editing
  • A new entry is added
  • Periodic trigger
  • Periodic trigger for entries that meet certain conditions
If you select this event as a trigger, the corresponding automation will be fired each time an entry in the selected table view meets certain conditions after editing.
In the conditions, you can specify individually for each column what the corresponding value must look like after editing in order to trigger the automation. In the course of this, you can decide whether all or only selected columns of the table view are to be monitored for the occurrence of the trigger event.
Entries meet certain conditions after the change
If you select the event “Entries meet certain conditions after editing” as a trigger of an automation, the following automatic actions are available for selection:
  • Send notification
  • Send app notification
  • Send e-mail
  • Addrow
  • Lock entry
  • Edit entry
  • Add links
  • Add new entry in other table
  • Run Python script
Automation trigger: A new entry is added
If you select this event as a trigger, the corresponding automation will be fired every time a new entry is added in the selected table view. In addition, you can further restrict the occurrence of the event by individually setting a value for each column that the new entry must contain to trigger the automation.
Possible restrictions of the trigger event: When a new entry is added
If you select the “A new entry is added” event as a trigger of an automation, the following automatic actions are available for selection:
  • Send notification
  • Send e-mail
  • Addrow
  • Lock entry
  • Edit entry
  • Add links
  • Run Python script
If you assign a periodic trigger to an automation, you can then define a time at which the automation is triggered daily, weekly or monthly. While you can only specify the time for a daily automation, you can also specify a day of the week for a weekly automation or an exact date for a monthly automation.
Setting options for a periodic trigger
When you set a periodic trigger for an automation, the following automatic actions are available for selection:
  • Send notification
  • Send e-mail
  • Addrow
  • Add links
  • Run Python script
  • Execute data processing operation
This trigger is a mixture of the periodic trigger and the “Entries fulfill certain conditions after processing” trigger. On the one hand, you can specify a time congruent to the periodic trigger at which the automation is triggered daily, weekly or monthly.
In addition, this trigger event allows you to individually specify for each column of the table certain conditions that the entries in the respective column must meet in order for the automation to be completed at the specified time.
Automation trigger: “Periodic trigger when entries meet certain conditions”.
If you select the “Periodic trigger for entries that meet certain conditions” for an automation, the following automatic actions are available for selection:
  • Send notification
  • Send e-mail
  • Lock entry
  • Edit entry
  • Convert page to PDF
