You want to add an app to your base to tailor the work in SeaTable even more individually to specific user groups and use cases? No problem! This is done in just a few steps.
Add an app to a base
- Open any base where you want to add a new app.
- Click Apps in the base header.
- A new window appears. Click Add App.
- Decide what type of app you want to create and click Add.
- Give the app a name.
- Confirm with Submit.
Once you have added the app, you can edit and customize it to your liking.
