Apps that you have already added to one of your bases can be edited at any time using the tab of the same name in the base header.
Edit an app
- Open the base in which you want to edit an app.
- Click Apps in the base header.
- Hover over the desired app and click the pencil icon that appears .
- The selected app will open in edit mode, where you can make certain settings .
