Especially when there are many tables with dozens of columns in a base, it is easy to lose track of how they relate to each other. Using the table relationships plugin, you can visualize which tables are linked to each other via which columns.
You can find out how to activate the plugin in a base here .
Table relations plugin
Once you have set up and opened the table relationships plugin, you will first see all the tables in the base. All columns that are created in the respective tables are listed under the colored table names.
To visualize the table relationships, you will not only see solid lines for direct links via link columns , but also dashed lines for indirect links via link formula columns (e.g. lookups .
By default, a graphic with all table relationships is already created when the table relationships plugin is opened for the first time. If you would like to create another graphic, click on Add new table relationship. This opens an input field in which you can enter the desired name.
Options of a table relationships graphic
To change the order of the graphics, hold down the left mouse button on the gripping surface and drag and drop a graphic to the desired position. You can also rename, duplicate or delete the graphics.
In the settings, which you can access by clicking on the cogwheel symbol , you can define the following for the graphic by (de)activating the sliders:
  • Would you like to display links to other entries (direct connections)?
  • Would you like to display formulas for links (indirect links)?
  • Do you want to display two-level formulas for links (e.g. a lookup formula that takes values from the lookup column of another table)?
  • Would you like to display tables without links?
Setting options for a table relationships graphic
You can move the various tables in the graphic as required using drag and drop. To do this, hold down the left mouse button, drag the table to the desired position and release.
Move tables in a table relationships graphic using drag-and-drop
