Este script calcula totales acumulados en las filas de una tabla. Para cada fila, suma el valor actual a la suma de todas las filas anteriores y escribe el resultado en una columna “Accumulated”. Gestiona automáticamente vistas agrupadas y no agrupadas.
base.auth()
TABLE_NAME = "Table1"
VIEW_NAME = "Default View"
COLUMN_CURRENT = "Value"
COLUMN_ACCUMULATED = "Accumulated"
# Look up view and table metadata
table = None
view = None
for t in metadata['tables']:
    if t['name'] == TABLE_NAME:
        table = t
        for v in t['views']:
            if v['name'] == VIEW_NAME:
                view = v
                break
        break
if not table:
    print(f"Table '{TABLE_NAME}' not found.")
elif not view:
    print(f"View '{VIEW_NAME}' not found.")
else:
    rows = base.list_rows(TABLE_NAME, view_name=VIEW_NAME)
    # Build a mapping from column key to column name
    col_key_to_name = {col['key']: col['name'] for col in table['columns']}
    updated = 0
    if view.get('groupbys') and len(view['groupbys']) > 0:
        # Grouped view: reset accumulated value per group
        group_col_key = view['groupbys'][0]['column_key']
        group_col_name = col_key_to_name.get(group_col_key, '')
        groups = {}
        for row in rows:
            group_val = row.get(group_col_name)
            if not group_val:
                continue
            group_val = str(group_val)
            if group_val not in groups:
                groups[group_val] = []
            groups[group_val].append(row)
        for group_val, group_rows in groups.items():
            accumulated = 0
            for row in group_rows:
                value = row.get(COLUMN_CURRENT, 0) or 0
                accumulated += value
                base.update_row(TABLE_NAME, row['_id'], {COLUMN_ACCUMULATED: accumulated})
                updated += 1
    else:
        # Non-grouped view
        accumulated = 0
        for row in rows:
            updated += 1
    print(f"{updated} rows updated.")
Adjust the four variables at the top to match your table. If your view is grouped, the accumulated value resets for each group.
