Este script fusiona varios archivos PDF almacenados en una columna de archivos en un único documento PDF y guarda el resultado de vuelta en la fila.
The complete script
import pdfmerge
from io import BytesIO
import os
base.auth()
TABLE_NAME = "Documents"
FILES_COLUMN = "PDF Files"
RESULT_COLUMN = "Merged PDF"
for row in rows:
files = row.get(FILES_COLUMN, [])
if not files or len(files) < 2:
continue
if row.get(RESULT_COLUMN):
continue
# Download all PDFs
tmp_files = []
for i, f in enumerate(files):
url = f if isinstance(f, str) else f.get('url', '')
content = base.download_file(url)
tmp_path = f"/tmp/pdf_{i}.pdf"
with open(tmp_path, 'wb') as fh:
fh.write(content)
tmp_files.append(tmp_path)
# Merge
output_path = "/tmp/merged.pdf"
pdfmerge.pdfmerge(tmp_files, output_path)
# Upload
with open(output_path, 'rb') as fh:
info = base.upload_bytes_file("merged.pdf", fh.read())
base.update_row(TABLE_NAME, row['_id'], {RESULT_COLUMN: [info.get('url')]})
# Cleanup
for f in tmp_files:
os.remove(f)
os.remove(output_path)
print("PDFs merged.")
The script skips rows that already have a merged PDF or have fewer than two files. Adjust the column names to match your table structure.
