Este script procesa registros de tiempo y genera estadísticas diarias de asistencia. Para cada empleado y día, determina la entrada más temprana (llegada) y la más tardía (salida) y escribe los resultados en una tabla de estadísticas separada.
You need two tables:
  • Time records: Contains columns Name, Date, and Time with the raw clocking data.
  • Statistics: Contains columns Name, Date, Clock in, and Clock out for the results.
base.auth()
TIME_RECORDS_TABLE = "Time records"
STATISTICS_TABLE = "Statistics"
# Clear statistics table to avoid duplicates on re-run
for row in base.list_rows(STATISTICS_TABLE):
    base.delete_row(STATISTICS_TABLE, row['_id'])
# Group time records by date and name
rows = base.list_rows(TIME_RECORDS_TABLE)
groups = {}
for row in rows:
    name = row.get('Name', '')
    date = row.get('Date', '')
    time = row.get('Time', '')
    if not name or not date or not time:
        continue
    key = f"{date}_{name}"
    if key not in groups:
        groups[key] = {'name': name, 'date': date, 'times': []}
    groups[key]['times'].append(time)
for key, group in groups.items():
    times = sorted(group['times'])
    clock_in = times[0]
    clock_out = times[-1]
    base.append_row(STATISTICS_TABLE, {
        'Name': group['name'],
        'Date': group['date'],
        'Clock in': clock_in,
        'Clock out': clock_out
    print(f"{group['name']} ({group['date']}): {clock_in} - {clock_out}")
print(f"---
{len(groups)} entries created.")
Adjust the table and column names to match your setup. The script always appends new rows – if you run it multiple times, clear the statistics table first to avoid duplicates.
