SeaTable for individual requirements with AI power
Workflow management – flexible and simple
SeaTable is your reliable and customized workflow management tool for process optimization. Create individual, automated workflows and monitor them in real time.
Flexible and adaptable
Workflow management with SeaTable
  • Flexible and intuitive
    With SeaTable, you can design workflows that are precisely tailored to your company’s requirements.
  • Visual design
    The user-friendly no-code platform allows you to design processes using drag-and-drop.
  • GDPR compliant
    SeaTable Cloud and our SeaTable AI server are hosted exclusively on certified European servers in Germany.
  • Scalable
    SeaTable scales with you and your growing requirements. Ideal for digitizing workflows.
  • Real-time collaboration
    Thanks to comprehensive real-time collaboration features, you can achieve maximum transparency.
  • AI-supported automation
    SeaTable helps you automate recurring processes and minimize manual intervention.
SeaTable Workflow Management Interface with Features
For your workflow
Your customized workflow management system
With the AI no-code solution SeaTable , you can create and automate customized workflows and keep track of all processes in real time. Thanks to the intuitive interface, you can get started right away without having to write a single line of code.
No complex implementation thanks to no-code
Real-time collaborative work
Integrated automation for lean processes
GDPR compliant
Authorization management
Fast and agile
Adapt to change
Companies face rapidly changing challenges. With a flexible, AI-powered workflow management system like SeaTable, you can respond quickly and agilely to new requirements and design resilient, intelligent workflows.
Efficient IT infrastructures
Stable workflow management
SeaTable offers a flexible AI no-code platform that requires no complex setup and gives you full control over processes and data. This takes the pressure off your IT department and empowers specialist departments to help themselves.
Safety and innovation
Establish data control and compliance
Take advantage of modern workflow automation without compromising data protection and retain full data sovereignty . Design innovative AI workflows without compromising data security or violating internal IT policies.
Digital transformation
Workflow management for businesses
With SeaTable, you can design your workflows to support your business strategy and help drive your digital transformation.
Workflow management without delays
A key advantage of SeaTable is its ability to enable real-time collaboration. In many companies, delayed workflows lead to inefficient processes and missed opportunities. With SeaTable, teams can work on workflows simultaneously, regardless of their location. All changes are synchronized in real time, so every employee is always up to date.
To learn how to optimize teamwork with SeaTable, check out our Online Course 3 , which features practical examples.
SeaTable Workflow Management View for Real-Time Team Collaboration
Integration
Connect SeaTable with your tools
Connect SeaTable with all the apps you already use and use SeaTable as the hub for your entire workflow.
Design streamlined workflows
Your Swiss Army knife
Examples of customized workflows with SeaTable
SeaTable offers countless possibilities for designing individual workflows that are perfectly tailored to the needs of your company. Here are a few examples:
  • Marketing
    Whether campaign management, content planning, monitoring, or reporting—with SeaTable, you can design efficient marketing management.
    Read more
  • Project management
    SeaTable allows you to create project plans and task lists that are updated and automated in real time. Deadlines and dependencies are always in view.
    Read more
  • Human Resources
    SeaTable supports you in managing and automating your HR processes. It enables seamless document integration and synchronization with other HR tools.
    Read more
  • License management
    Track license status, avoid compliance violations, and ensure your business always complies with the latest regulations.
    Read more
  • Sales
    Design your sales and CRM processes flexibly according to your requirements. Create automated sales processes, map deal pipelines, and strengthen customer loyalty.
    Read more
  • Finance
    Manage your finances in a single tool—from capital requirements and financing plans to financial reports. Create an AI workflow for automated analyses.
    Read more
Cloud or your own server
Your choice for the optimal workflow system
With SeaTable, you can choose between three powerful deployment options for your workflow tool:
SeaTable Cloud project plan template for planning finance-related projects
SeaTable Cloud
Perfect for companies that want to get started quickly and without extensive IT infrastructure—flexible and scalable.
SeaTable Server Action plan template for financial action packages
SeaTable Server
For companies that want to retain full control over their data, SeaTable Server offers an on-premises option.
SeaTable Dedicated environment for company-wide financial and planning processes
SeaTable Dedicated
For companies that need the simplicity of the cloud and the flexibility of a self-hosted system.
No compromises when it comes to data protection
Your GDPR-compliant software for automated workflows
  • Hosting in Germany
    SeaTable and the SeaTable AI are hosted on licensed servers in Germany. For GDPR-compliant AI functions.
  • Security settings
    Set up individual access and editing rights and restrict access to sensitive data.
  • Authentication and SSO
    SeaTable supports all common authentication techniques and enables 2FA and SSO.
Try out the smart solution for smart processes
FAQ – Workflow Management with SeaTable
What is a workflow and why is it crucial for businesses?
A workflow is the systematic sequence of tasks and processes that must be completed within a company in order to achieve specific goals. Well-structured workflow management enables companies to save time, minimize errors, and significantly improve teamwork. However, in many companies, a large part of the workflows are still carried out manually, which leads to delays, errors, and inefficiencies. This is where an effective workflow management tool like SeaTable comes in. It allows you to digitize your workflows, automate them with AI support, and integrate them seamlessly. Recurring processes such as data entry, status reports, or approvals are simplified through intelligent automation, while manual intervention is reduced to a minimum. This not only saves a considerable amount of time, but also significantly reduces sources of error. With a flexible and AI-enabled workflow management tool like SeaTable, companies can quickly adapt their processes to meet current market requirements while maintaining control over security, IT compliance, and license management.
How can SeaTable help manage the rapid change in business requirements?
SeaTable is flexible, customizable, and AI-powered. As a workflow management tool, it allows you to quickly adapt workflows to new business requirements without the need for complex IT changes. Through AI-powered process optimization , SeaTable automatically detects bottlenecks and suggests targeted adjustments. This allows you to respond more quickly to market changes and secure your competitiveness.
How does SeaTable ensure IT security with innovative solutions?
With SeaTable, you can create innovative, AI-powered workflows without compromising on security. With self-hosting options and compliance with the strictest security standards, all data, including AI-processed content, remains protected in accordance with GDPR. With our self-hosted AI server, you can also create AI-powered workflows without compromising on compliance. SeaTable thus offers the ideal combination of innovation, data sovereignty, and security.
How does SeaTable help align IT and business strategies?
With SeaTable, you can design your workflows to actively support your business goals. AI-based analytics help reveal dependencies between IT processes and business goals. This allows you to ensure that your digital strategy is closely aligned with your business goals and that IT seamlessly harmonizes with business requirements.
Can SeaTable help with the integration of new technologies?
Yes. With its flexible API and support for external automation platforms, SeaTable can be easily connected to modern technologies and AI services. This allows you to extend existing systems, integrate new technologies, and gradually modernize your processes—without adding software complexity.
How does SeaTable improve license management and software compliance?
With SeaTable as your workflow management software, you can keep track of your software licenses and ensure that your IT remains fully compliant. By automating your license management and regularly checking for compliance, you can ensure that all software licenses used comply with current regulations at all times.
Can I create custom workflows and automations in SeaTable?
With SeaTable, you get a powerful no-code tool that greatly simplifies the creation of custom workflows and automations. Thanks to integrated AI functions, you can automatically prioritize tasks, optimize workflows through self-learning, and intelligently control notifications or reports. In addition to integrating common automation tools, SeaTable offers the option of seamlessly integrating your own systems and AI models into your workflow management system via the API.
How can I process my data with AI in SeaTable without transferring it to other servers?
SeaTable offers a modern workflow automation editor with integrated AI functionality. To ensure the security of your data, we host our own AI model on a German server. When you execute AI actions in automated workflows, the data is transferred to our AI server, processed there, and then returned. No data is transferred to other servers outside the SeaTable infrastructure.
Would you like to learn more about how you can use SeaTable to automate your workflows efficiently?
Send us a message – we'll get back to you promptly
If you are using the free SeaTable Free cloud plan, the self-hosted Developer Edition, or the free 3-user license and need assistance, please visit our Community Forum .
At this time, we are unfortunately unable to provide direct support for users without a paid license. However, you will receive fast and competent help from our community in the forum.
As a customer with a SeaTable Cloud Plus or Enterprise subscription, you can create support tickets directly in the Team Administration .
The advantage: You can keep track of all your tickets and their processing status in one place. Mehr erklärung!
A telephone number allows us to respond particularly quickly.
More information
