SeaTable Server
All SeaTable features on your own server
Installing SeaTable On-Premises on your own servers is the perfect solution for companies that want full control over their data. With just one instance - your own infrastructure - you maintain complete sovereignty over your data and can fully customize the system to your needs.
Location-independent
With great power comes great responsibility
SeaTable is one of the few cloud solutions that you can also get as an on-premises solution.
You license a SeaTable Enterprise Server and can install and operate the server software wherever you want.
Use all SeaTable features while remaining independent: You decide how much support you want from us.
SeaTable Server interface for on‑premises operation with full data control
Full control
The advantages of your own SeaTable server
With your SeaTable Enterprise System, you can use your own URL, templates, custom color codes as well as roles and permissions.
At the same time, SeaTable supports all common authentication techniques like SAML, OAuth, Shibboleth, Active Directory and LDAP. It enables two-factor authentication and single sign-on and supports cluster-capable backends like Ceph and S3.
In your system, you determine which API limits should apply or whether any should apply at all.
SeaTable on‑premises system architecture with dedicated server infrastructure
Support and services
You have control over your server.
Nevertheless, you can use our help whenever you want.
  • Installation
    Save yourself the trouble of learning about SeaTable’s special features. We’ll handle the one-time installation for you.
  • Maintenance and support
    We can also support you during ongoing operations. From minor updates to complete OS updates, we handle everything.
  • Consulting, training and workshops
    Benefit from our extensive experience in using SeaTable.
  • Custom development
    We’re also happy to help with the development of plugins, scripts or templates. Contact us.
  • Corporate Support
    On request, we offer you better response times and better support.
  • What are you waiting for?
    Contact us
Comparison of our products
The three SeaTable products at a glance
Editions
Cloud
Dedicated
On-Premises
Free to use
(only SeaTable Free)
(up to 3 users)
Administration
Any server location
Automatic updates
Own administration
Linux command line access
Custom authentication
Customizing
Custom logo
(only SeaTable Enterprise)
Custom URL
Custom templates
Custom user roles
Support
Optional corporate support
Requirements
Email address
Min. 100 users
Linux server or VM
More information
