The structured Notion alternative for teams
Notion works well as a notebook or idea collector, but performance drops noticeably once you have just a few hundred entries. Real-time team collaboration and table linking are only possible to a limited extent. And if you don’t want to use an expensive business account, your data will be stored in the U.S. If you’ve had enough of that, then the AI-powered no-code solution SeaTable is the right tool for you: true relational databases, flexible views, and GDPR-compliant hosting—all in one scalable platform.
That’s why SeaTable
The Notion alternative that does more
  • True relational databases
    Notion does not support true lookups, and rollups are limited to a single level. SeaTable offers the full range of relational database features, including cross-level joins and referential integrity.
  • Views for every application
    In SeaTable, you can use different views to visualize your data exactly as you need: with Kanban, table, calendar, gallery, timeline, map, tree view, or statistics. One data, multiple display options.
  • AI-powered automation
    Use our AI-powered automation tools to categorize, translate, and summarize data or extract text from images. With our AI chat plugin, you can connect SeaTable to your AI agent.
  • Collaborative Work
    Work with your colleagues in a Base at the same time—without any performance issues. Real-time updates, permissions, chat, and notification features make SeaTable a true team tool.
  • Assets and Media
    Store not only text, but also images, videos, documents, and metadata in a structured database. Use them in automations and emails, or incorporate them into presentations.
  • Page Designer & Report Builder
    Create professional documents and reports directly from your data. With the click of a button or through automation, you can generate print-ready PDFs and send them directly from the system via email.
SeaTable as an alternative to Notion for project management and knowledge management
Real database power for business data
The powerful alternative to Notion
If you’ve already used Notion, you know that the tool quickly reaches its limits when it comes to structured business data. As an alternative to Notion, the AI-powered no-code solution SeaTable combines the flexibility of no-code tools with the power of a relational database.
No-code app builder for user-friendly front ends and fully-featured self-service portals
Real-time collaboration and integrated notifications for true teamwork
Intuitive access and flexible data structures
As a GDPR-compliant cloud solution hosted exclusively in Germany or self-hosted
Consistent performance and transparent pricing, even with large data sets and teams
From project management to a knowledge base
SeaTable: One tool, countless features
True table links
In Notion, every database is essentially a note. Links are limited to a single level, rollups can handle a maximum of 25 values, and lookups are editable dropdown fields without validation. With SeaTable, you can create cleanly structured, consistent, and relational data across multiple levels.
With SeaTable as an alternative to Notion, you can harness the power of true relational data links
Documents, Dashboards, and Visualizations
SeaTable, the alternative to Notion, is more than just a database. With its built-in whiteboard, you can create freehand sketches and process visualizations. With the Page Designer and Report Builder, you can create print-ready documents and reports directly from your tables. And with the statistics module, you can build attractive analysis and monitoring dashboards.
SeaTable is a Notion alternative that offers attractive dashboards and data visualizations
Chat, Notifications, and Email Integration
With Notion, your team needs external channels to discuss tasks. SeaTable offers built-in features for this: Use the chat feature to discuss individual tasks, and receive automatic notifications for important updates. Native email integration allows you to send emails directly from the database.
SeaTable, an alternative to Notion, offers built-in communication features
App Builder
With Notion, you need external tools to turn your pages into apps. In SeaTable, the App Builder is built right in. This lets you quickly turn any base into fully customizable apps with forms, list views, and role-based access controls, which you can share with external users with password protection if needed.
With SeaTable as an alternative to Notion, you can create front ends and self-service portals
Automated Workflows
Notion’s automations are limited and cannot handle multi-step workflows. SeaTable offers native automations with triggers based on schedules, status changes, or new entries, and multiple actions with built-in AI features.
SeaTable, an alternative to Notion, offers smart AI-powered automations for streamlined workflows
The scalable alternative to Notion
High-performance even with large amounts of data
Notion isn’t designed as a database, but as a block-based workspace. And it shows: as soon as you create a lot of workspaces or have multiple people working on them, performance drops significantly. Seatable can support hundreds or thousands of users and large amounts of data without any performance limitations or increased costs.
Handy templates to get you started
How to Get Started with SeaTable, the Notion Alternative
To make getting started as easy as possible, we offer a wide range of free, ready-to-use templates, YouTube videos, and numerous help articles to guide you through the first steps. Whether you need knowledge management software or a project plan.
Project Structure Plan
SeaTables Project Structure Plan Template for Smart Project Management
Product Launch
SeaTables Template for a Successful Product Launch
Workshop Plans
SeaTables Workshop Planner Template for Successful Events
Are you ready for real database power?
Standard Integration
SeaTable integrates with your favorite tools
The seamless integration of various tools is another advantage of SeaTable as an alternative to Notion. Thanks to SeaTable’s flexible API, you can seamlessly integrate additional tools—tailored to your specific needs.
No compromises on data protection
Your Notion alternative for full compliance
With SeaTable, the Notion alternative, you can rest assured that your data is hosted exclusively on European servers in Germany. With single sign-on and granular access permissions, your data is further protected.
  • Hosting in Germany
    The SeaTable Cloud and the SeaTable AI Server are hosted in certified data centers in Germany—and are fully GDPR-compliant.
  • Access permissions
    In SeaTable you can set up custom role permissions and restrict access to sensitive data using granular access and editing rights.
  • Authentication and SSO
    SeaTable supports single sign-on, two-factor authentication, and other common authentication methods.
Comprehensive features across all pricing plans
Notion alternative self-hosted or in the Cloud
SeaTable Cloud: The Perfect Alternative to Notion
SeaTable Cloud
Perfect for businesses without an extensive IT infrastructure—flexible and scalable.
SeaTable Server as a Notion alternative for full control over your data
SeaTable Server
For companies that want to retain full control over their data.
SeaTable Dedicated Environment for Scalable Project and Knowledge Management in the Enterprise
SeaTable Dedicated
The simplicity of the cloud combined with the flexibility of a self-hosted system.
Switch now for consistent performance and true structure
FAQs – SeaTable as Notion alternative
Can data be migrated from Notion to SeaTable?
Yes, you can export your Notion database as a CSV file and import it directly into SeaTable.
Can I also create documents in SeaTable?
Yes, that’s no problem. With the Page Designer, you can create structured documents directly from your data and, if needed, send them via email directly from the database. The Report Builder automates recurring reports.
How does SeaTable compare to Notion in terms of cost?
SeaTable offers a permanently free plan for up to 25 users that already includes all essential features for productive work. And even with the Plus and Enterprise subscriptions, SeaTable costs €7 per user/month and €14 per user/month, respectively—less than comparable Notion costs.
For which teams is SeaTable a suitable alternative to Notion?
SeaTable is particularly well-suited for teams that use Notion as a database and are running into performance, structural, or data privacy limitations.
Does SeaTable also offer support?
Yes, in addition to extensive help articles and YouTube tutorials , SeaTable also offers free support via our forum. You can also contact us directly via our contact form or by email.
Is SeaTable truly GDPR-compliant?
Yes, SeaTable is a German company and hosts the SeaTable Cloud exclusively on servers belonging to the Swiss company Exoscale in a Frankfurt data center. Our SeaTable AI Server is hosted on German servers. This makes SeaTable the fully GDPR-compliant solution among the Notion alternatives on the market.
Is SeaTable open-source?
SeaTable Server is partially open-source as a Notion alternative. The self-hosted version of SeaTable is based on an open-core model, in which the core of the platform is open-source and available on GitHub, while advanced enterprise features are proprietary. Anyone who wants to run SeaTable as a self-hosted alternative to Notion can review the source code, customize it, and operate the platform entirely under their own control.
How does Notion compare to Airtable and other no-code databases?
Notion is strong for documents and wikis, but weaker as a database, especially for links and large data volumes. How Notion, SeaTable, Airtable, Baserow and other tools compare in terms of price, hosting and features is shown in our comparison of the 8 best Airtable alternatives.
More information
