With an investment, you tie up financial resources in tangible or intangible assets for a certain period of time – freely available money becomes tied-up capital. These are usually fixed assets, i.e. things that remain in your company for a long time, such as buildings, machines or patents. Investments in current assets can be, for example, goods or raw materials that you process or sell and that are only in your possession for a short time.
An investment plan gives you an overview of all planned investments and provides information on how much money you want to invest and when. To do this, you record all expenses that are incurred once at the beginning through the acquisition or in the start-up phase of a project. Ongoing costs for operation and maintenance, on the other hand, do not belong in the investment plan, but in the operating resources plan. Together with any start-up costs, these two plans form the capital requirements plan, which is also part of your financial planning or your business plan.
If you set up a company or are in a management position, you are always faced with important investment decisions. Whether you want to buy new machinery, hire staff or drive digitalization – every decision influences the future growth and success of your company. With a well thought-out investment plan, you can manage your expenditure with foresight, set clear priorities and avoid unnecessary risks.
Furthermore, investments usually result in a high capital requirement, which you can often only cover with external lenders such as banks and investors. Convincing investment planning shows them that you can handle money and increases your creditworthiness. Last but not least, in the investment calculation you also calculate the potential benefit of your investments and determine when your capital investment will be profitable.
Investment plan and investment calculation
Depending on the objective and timing of an investment, 4 types of investment can be distinguished:
Initial investment
An initial investment, also known as a start-up investment, comprises all the expenses you incur for the initial equipment of your company to get your business off the ground. As a rule, the capital requirement is highest for this type of investment. A distinction is made between genuine investments and pure start-up costs such as registrations with the authorities, which do not contribute to increasing the value of your company.
Expansion investment
Expansion investments are expenses with which you expand your capacities. For example, if the demand for your products or services has increased, you should include more machines or personnel in your investment plan. An expansion investment usually pays for itself after a short time, as it is accompanied by a foreseeable increase in turnover.
Rationalization investment
The main thing you expect from a rationalization investment is a cost saving. For example, you could invest in robots to automate and speed up production processes in order to save on personnel costs. Compared to an expansion investment, however, you are not increasing capacity, but mainly efficiency.
Replacement investment
A replacement investment is necessary if you need to completely replace an obsolete or defective asset in order to keep your business running. This is also known as reinvestment. It is simply a matter of maintaining or restoring the previous state without changing the capacity or efficiency of your business.
As you can already see from the different types of investment, the time of acquisition and the expected useful life of capital goods play a decisive role in your investment planning. You should therefore draw up your investment plan not only for the start-up, but for the entire life of your assets.
In an investment plan for machinery, for example, you define for each machine how long you want to use it and when you will probably have to replace it. During the useful life, you should therefore not only generate the acquisition costs, but also build up reserves so that you can replace the machines when the time comes.
Inspection of machines
The hypothetical costs for these reserves appear in the balance sheet (e.g. in the annual financial statements) as depreciation. Specifically, it takes into account the depreciation of the asset over its entire useful life. For example, if you buy a machine for 20,000 euros that is to remain in your company for 10 years, the value is reduced by 10 percent each year, i.e. 2,000 euros, which you enter as depreciation in the income statement.
  1. Define your goals: For example, do you want to expand production capacity to respond to increased demand or enter new markets? Then this suggests an investment plan for more machines. In other words, you should be clear about what you want to achieve with each investment.
  2. Clarify the financing: Analyze how much money you need for your project and how you can finance it. Whether equity, loans or subsidies – you decide which financing suits your investment.
  3. Set priorities: Not everything that is desirable can be financed. Determine which investments have the highest priority and which you can postpone. Prioritize investments that strategically contribute to your goals and have a direct impact on your business.
  4. Calculate costs and benefits: Naturally, your investments should bear fruit as quickly as possible. Therefore, carefully calculate the costs you will incur and the benefits you expect for each investment. Such a cost-benefit analysis will help you avoid unnecessary bad investments.
  5. Plan the time horizon: An investment plan helps you to schedule necessary expenditure and deploy funds in such a way that financing is secured in the long term. Thanks to a realistic schedule of when you will purchase which capital goods, the risk of liquidity bottlenecks is reduced.
  6. Realize your investment plan: The financing, significance, benefits and timing of your investments have been clarified? Then nothing stands in the way of implementing your investment plan! Check regularly whether your investments are actually achieving the desired success and adjust your plan if necessary.
Imagine that you want to set up your own garage and need to draw up an investment plan, for example. You make the following investment decisions: You don’t want to rent a garage, but buy a property with a workshop and office. Naturally, this property will be the largest item in your investment plan.
Investment plan example garage
Next, you will need a lifting platform and various electrical devices and tools for your workshop, which you enter in the investment plan under machinery and equipment. Other items of equipment for the workshop and office could include a fitted kitchen, desks, seating, workbenches, shelving systems, computers and telephones. In the future, you also want to invest in your own tow truck, a second lifting platform and a table football table for breaks.
In the example described above, the investment plan could have a structure like this:
Type of investment Year 1 Year 2 Year 3
Real estate
Garage with office 350,000 – –
Machinery/equipment
Lifting platforms 5,000 – 5,000
Electrical equipment 10,000 5,000 –
Tools 5,000 – 2,000
Vehicles
Tow truck – – 70,000
Furniture
Workbenches 5,000 – –
Fitted kitchen 5,000 – –
Desks 1,000 – 500
Seating 1,200 – –
Shelving systems 500 – –
Table soccer – – 500
IT
Computers & monitors 2,800 700 1,000
Telephones & routers 1,000 – 500
Current assets
Basic spare parts 2,000 1,000 1,000
Gasoline, oils 500 500 500
Gloves, clothing 500 300 500
Other 500 500 500
Investment amount 390,000 8,000 82,000
All figures in this investment plan example are net prices in euros.
You should avoid the following pitfalls to ensure that your investment planning is a success:
  • Confusion with capital requirements planning: The investment plan only covers part of the capital requirements. Take into account additional expenses, especially for ongoing operating and personnel costs.
  • Unclear goals or priorities: Before you invest even one euro, you should have clarified how urgent certain investments are and which investment contributes most to your business goals. This way you will always know what you should spend money on immediately and what you can wait on.
  • Underestimate costs, overestimate benefits: Don’t be too optimistic about the effect of your investments. Sometimes it takes longer than expected for the acquisition costs to be amortized. It is better to calculate too much than too little in terms of costs so that you have a buffer for unforeseen price increases.
  • Gut feeling instead of calculations: Even if you are not a big fan of math, you should carry out the investment calculation seriously and carefully. For example, calculate the profitability of different investments to make the right investment decisions.
Investments can be worthwhile
While a template in Excel or Word may suffice for a simple investment plan, the data volumes and structures in larger companies quickly become unmanageable and complex. The no-code database SeaTable, for example, is the ideal investment planning software to help you maintain an overview. The intuitive user interface is reminiscent of a spreadsheet, but SeaTable offers significantly more functions and even the option to create your own apps.
With the help of formulas and statistics, but also views and plugins (such as galleries, calendars, Kanban boards), you can evaluate and visualize your data in no time at all. SeaTable also supports collaboration within your company, for example with its comment function and real-time synchronization of changes. Granular authorizations allow you to control exactly who can see and edit which data. Last but not least, you can use the App Builder to design individual interfaces and processes. For example, you could use a form for investment requests, which everyone in the company can use to submit their requests for purchases.
For founders in particular, professional investment planning software often means high costs before any revenue flows in. Good thing SeaTable is scalable: start with the free version, which already offers you all the basic functions, and only pay for upgrades if you need more storage space, features or user accounts. SeaTable grows with your requirements and your team!
You also have the choice of whether you prefer the convenience and scalability of the cloud – or whether you want to enjoy the full data sovereignty of an on-premises installation with SeaTable Server. If you use the SeaTable Cloud, your data is stored in German data centers in compliance with the GDPR and protected from being passed on to servers in the USA and other countries.
What is an investment plan?
The investment plan is the part of your business or financial plan that lists all planned expenditure for the long-term acquisition of machinery, buildings or other assets. Together with the working capital plan, it is used to determine your capital requirements.
What does an investment plan look like?
As a rule, an investment plan is a tabular list of all planned investments. The appearance and scope of the investment plan can vary depending on the complexity and size of your company. For example, it may be a multi-year investment plan for machinery and equipment or an investment plan for a business start-up.
What should you consider when planning investments?
When it comes to professional investment planning, it is not that easy to explain. First and foremost, it is about clarifying objectives and priorities, calculating costs and benefits, carrying out a thorough investment appraisal and then making well-founded decisions. The time factor also plays a major role. Particularly when setting up a company, you should not forget that the capital requirements go well beyond the investments. If you would like more detailed information on investment planning and more explanation, you can find this in the article.
What is depreciation?
With the help of depreciation, you create balance sheet reserves for replacement investments. Depreciation refers to the reduction in value of assets over their entire useful life. For example, if you invest 60,000 euros in a company car that you want to use for 20 years, the annual depreciation is 5 percent (one twentieth) of the purchase value, i.e. 3,000 euros.
TAGS: Finances Build Your Business
