With the help of automations , you no longer have to manually record the times of a status change, but can have SeaTable do this automatically.
Send emails via automation
  1. In the base header, click and then click Automation Rules.
  2. Click Add Rule.
  3. Give the automation a name and specify the table and view in which it should act.
  4. Define the trigger event that triggers the automation.
  5. Click Add action and select Add new entry in other table as automated action.
  6. Define the table where the entry should be inserted and the pre-filled fields.
  7. Confirm with Submit.
First define the appropriate trigger event for the automation.
Trigger events basically available for selection
Then select Add new entry in other table as automated action.
Adding the automated action
Selection of the automated action
In the next step, select the table to which the entry will be added after the trigger is fired.
Selection of the table in which the entry is to be added after triggering the trigger
Next, click Add Field to select the columns for which you want to define specified values in the new entry.
Click Add Field
Now select a corresponding column from the drop-down menu and define the pre-filled value in the input field. Depending on the selected column type , you have different options to choose from.
Definition of the entry and the column to be added to it
Finally, confirm the automation by clicking Submit.
Automation confirmation
A concrete use case for this type of automation could occur, for example, when you want to record the various orders for your company in a table.
In doing so, you want to automatically record the times at which changes to the order status occur for one or more orders in your table in another table. This way, you can keep track of the status of your orders at all times and track every status change from “Payment required” to “Product successfully delivered”.
In concrete terms, this can be implemented with the help of a table (“Order”) in which you record the various orders that you have placed for your company. In this context, you could collect the order number, the amount and the status of the individual orders.
Table for the survey of the various orders placed
In another table (“Order status log”) you also want to see the different order numbers together with the corresponding amounts. In addition, the date column “last status change” in this table contains the time of the last status change.
Table in which the times of the last status change are automatically collected
Using an automation, every time you change the status of an order in the Order table, the time of the status change should be added to the last status change column in the Order Status Log table. In addition, the automation will also automatically add the order numbers and amounts to the Order Status Log table.
First, give the automation a name and select both the table (“Order”) and the view (“All Orders”).
Basic automation settings
As a trigger event of the automation, select the option Entries fulfill certain conditions after processing.
Definition of the trigger event
Add as a filter condition that the Status column in the Orders table must not be empty after editing to capture the status changes.
Adding a filter condition for triggering the trigger event.
As an automated action you define the action Add new entry in other table.
In the next step, select the “Order status log” table as the table to which the time of the status change will be added after the automation is triggered.
Selection of the table to which the entries will be added when the automation is triggered
Then define the values with which certain fields are to be pre-filled. To ensure that the respective time of a status change is always automatically added to the date column “last status change”, define the value Day of execution for this column.
Definition of the values that are automatically added to the table when the automation is triggered
Um die verschiedenen Bestellnummern und die dazugehörigen Beträge in der Tabelle “Order-Status-Log” zu zitieren, schreiben Sie die Spaltennamen in geschweiften Klammern in das jeweilige Textfeld: {Order-ID} & {Amount}
When you change the status of various orders in your table after confirming automation, …
Adjustment of the status of various orders
… both the times of the status changes and the defined entries (order number & amount) are automatically entered in the “Order Status Log” table.
Table Order status log after triggering automation
