By default, SeaTable displays all rows with a compact row height to show as many records as possible. However, with this simple row height, among other things, text and multiple selection columns are truncated and only small thumbnails of images are displayed.
This row height may be suitable for most of your use cases, but there may be situations when you want to see more content of the respective rows . That’s why SeaTable allows you to adjust the row height in each of your views.
Specifically, four different line heights are available for this purpose:
- Simple (the default value for new tables and views)
- Double
- Triple
- Quadruple
Adjust row height
- Click the row height icon in the view options.
- Select the desired line height.
