If you want to give “instructions” to other users or record additional information about a base, you can add a description to a base in SeaTable. The description is automatically opened when a user opens the base for the first time.
Add a description to a base
- Click the info icon directly to the right of a base’s name.
- An input mask opens where you can add a description to the base.
- Your changes will be saved automatically when you close the input mask using the X icon .
