You are interested in SeaTable Cloud, but you are still unsure about the technical requirements? No problem, in this article you will find all the technical information about browser, operating system, etc. that you should know in advance.
  • SeaTable Cloud has no requirements for RAM, CPU or similar.
  • You don’t need a specific operating system on your device. SeaTable Cloud is supported by any operating system.
  • All you need is a current browser with JavaScript enabled - we recommend Chrome. Other browsers, for example Firefox, may differ slightly in display and functionality.
