You have read-only access to your bases and cannot add any more data? Then you have reached a limit in your subscription. Don’t worry, your data is safe, you just can’t edit it anymore until you increase your subscription limits or free up space.
Possibilities in case of exceeded limits
To be able to further edit your bases and add data, there are basically two different options available:
- Delete part of your data (bases, tables, groups, etc.) to free up storage space until your limits are no longer exceeded. A Overview about the memory limits you are currently using can be found in the drop-down menu on the home page.
- Switch to a subscription that gives you higher limits.
