Common datasets can so far only be created from views of group bases. This is due to a technical limitation that may be removed in one of the future versions of SeaTable.
This circumstance is also referred to by a short info text that appears as soon as you want to publish a common dataset from a table view of a base that does not belong to a group.
Note if you want to publish a common dataset from a view from a base from the “My bases” area.
To be able to create a common dataset from a table view of a base that does not belong to a group, there is a simple way around the technical limitation described above:
  1. Copy the corresponding base to any group.
  2. Create a common dataset from the desired view.
