You cannot create automations in your bases? A possible cause could be an insufficient subscription .
Here you will find the automation function, if it is available in your subscription:
rows Locking and archiving with automation
If you want to use this powerful feature of SeaTable in the future, you can upgrade to an Enterprise subscription.
Automations are currently only available for teams with a SeaTable Enterprise subscription are currently only available to teams with a SeaTable Enterprise subscription. If you cannot find this feature in your bases, your team probably does not have such a subscription. To use automations, you need to upgrade your team’s subscription to an Enterprise subscription.
