With the help of automations, you no longer have to link entries in your tables manually, but can have these steps performed automatically. Simply define a corresponding automation for any table view.
Linking entries via automation
- In the base header, click and then click Automation Rules.
- Click Add Rule.
- Name the automation and specify the table and view in which it should act.
- Define a trigger event that triggers the automation.
- Click Add Action and select Add Links as the automated action.
- Confirm with Submit.
Creating the automation
First define a trigger event for the automation.
