To verify the authenticity of incoming webhooks from SeaTable in n8n, each request is sent with a digital signature in the header x-seatable-signature. This signature is based on the shared secret (Webhook Secret) and the request body.
In n8n you can implement the validation as follows:
Set up a
Webhook Triggerin your workflow. Make sure to enable theRaw Bodyoption. -
Add a
Crypto Node, where you hash the request body along with the secret using the HMAC-SHA256 algorithm to calculate the signature.
Now compare the signature calculated by the Crypto Node with the value from
x-seatable-signature. Note that you must prependsha256=to the calculated hash.
Only if both values match, the request is considered authentic.
This ensures that your n8n workflows only accept webhooks triggered by SeaTable and remain unaltered.
