You can undo actions in SeaTable in two different ways. SeaTable supports both the well-known key combination CTRL +Z as well as a corresponding option by mouse click. Here you will learn how to undo your last work steps and entries:
Undo actions via key combination
If you are currently editing a base or table and you want to undo one or more entries, just press the key combination CTRL +Z to press. Each time you type this key combination, SeaTable will undo your last change.
Undo actions by mouse click
Alternatively, you can undo your last action with a mouse click in SeaTable’s web interface.
- In the top right corner of the base header, click Versions and in the drop-down menu that opens, click Undo.
- With each click you undo your last change.
Frequently asked questions
How long can you undo changes?
What can all be undone?
The following actions can be undone:
- Inputs/changes in a cell
- Changes to the columns (name, type, position)
- Sequence of rows
Actions that cannot be undone
Some operations cannot be undone. These include, but are not limited to:
- Locking rows
- Changes to sorting, grouping or filters
- Comments
