For the optimal overview of the data in your table, SeaTable offers you views in which you can store your filters, sorts and groupings. You should give these views a meaningful name. Even afterwards, you can rename your views at any time.
  1. Click the name of the current view.
  2. Hover the mouse over the view you want to rename.
  3. Three points become visible in the view line. Select them.
  4. Select the Rename View option.
  5. Delete the old name and enter a new one.
Rename a view
