A webhook from SeaTable has a uniquely defined structure. This allows easy processing of the event by any programming language. This article presents the general structure and the possible values.
When a webhook is set up for a base, an HTTP request is sent for each change to the contents of the base. Thus, for example, the following changes trigger a webhook:
  • A new row is added or duplicated.
  • A row will be deleted.
  • A line content is changed.
  "event": "update",
  "data": {
    "dtable_uuid": "fae0a3a42ba94df88e8303fd385e37de",
    "row_id": "Fk-i7xZGS5iA5aSvaG5HAA",
    "op_user": "4bc9a7c79c5942c5b6238413f2132bea@auth.local",
    "op_type": "insert_row",
    "op_time": 1649922777.279,
    "table_id": "9g8f",
    "table_name": "Opportunities",
    "row_name": "",
    "row_data": []
  "event": "update",
  "data": {
    "row_id": "QoNno3QiTF26sxmG1sl3_g",
    "op_type": "modify_row",
    "op_time": 1649929622.589,
    "table_id": "9g8f",
    "row_name": "",
    "row_data": [{
      "column_key": "589r",
      "column_name": "Prio",
      "column_type": "single-select",
      "column_data": {
        "options": [{
          "name": "++",
          "color": "#F4667C",
          "textColor": "#FFFFFF",
          "id": "381992"
          "name": "+",
          "color": "#FBD44A",
          "id": "830278"
      "value": "381992",
      "old_value": ""
  "event": "update",
  "data": {
    "op_type": "delete_row",
    "op_time": 1649929650.668,
    "table_id": "9g8f",
    "row_name": "",
    "row_data": []
The sent request of a webhook always contains the values “event” and “data”. The value “event” is currently always “update”. In the future, it is possible that other values will be added here.
The value “data” contains an array with further elements. These are listed in the following table:
Value Type Example
dtable_uuid String (32) fae0a3a42ba94df88e8303fd385e37de
row_id String (22) QoNno3QiTF26sxmG1sl3_g
op_user String (32) + “auth.local” 4bc9a7c79c5942c5b6238413f2132bea@auth.local
op_type insert_row, delete_row, modify_row insert_row
op_time Timestamp 1649929650.668
table_id String (4) 9g8f
table_name String Tasks
row_name String
row_data Object { … }
op_app String API token name
Equipped with this structure, you can now develop your own Webhook interface.
