You want to find out who added a row? Then create a column of the type creator . Here the name of the user who created the column is unchangeable.
Create the creator column
- Add a new column using the plus symbol in the table header.
- Give the column a name.
- Select the Creator column type.
- Click Submit.
Show more row details via columns
In addition, you can use other column types to display when a row was created and last edited and who changed it as the last editor.
