To ensure successful communication between your Identity Provider (IdP) and SeaTable Cloud as the Service Provider, the following technical and organizational requirements must be met.
List of Requirements
Support for the SAML 2.0 Protocol
The IdP must support standard-compliant SAML 2.0, which SeaTable uses for authentication.
Ability to Create Applications and Use SeaTable-specific URLs
The IdP must allow the creation of applications and correctly configure and use the URLs provided by SeaTable Cloud for login, logout, and Assertion Consumer Service (ACS). Specifically, the URL for fetching the metadata XML must be directly accessible and must not redirect to another domain.
Transmission of Required SAML Attributes
At minimum, the following user attributes must be passed from the IdP to SeaTable:
contact_email (user’s email address)
name (user’s full name)
uid (unique user identifier that remains unchanged throughout the user’s lifecycle)
Validated SSL Certificate
The certificate provided by the IdP must be valid and trustworthy to ensure the integrity and security of authentication messages.
Access to Metadata
The IdP should provide metadata information (metadata URL) that can be stored in SeaTable.
Domain Ownership Verification
To assign SSO-enabled users to a SeaTable team, the email domain must be verified via a TXT record entered in the DNS.
Technical Ability to Create and Configure Applications
Your IdP must allow the creation of an application (connector) and its configuration to process authentication requests and assertions correctly.
Support for Signed Assertions
To enhance security, the IdP should issue signed SAML assertions and optionally allow SeaTable to sign authentication requests.
Successfully Tested Identity Providers
The following identity providers have already been successfully tested with SeaTable Cloud:
