You have various options for adding new entries to the calendar. You can do this in the underlying table by creating a new row there and entering an appointment in the date column , which is then also displayed in the calendar plugin.
But it is also very easy to make new entries directly in the calendar plugin. There it depends on the selected display**(year**, month, week, day or agenda) how you can enter an appointment.
Create new calendar entry in the calendar plugin
  1. Open the calendar plugin and select the month or week display option.
  2. Hover the mouse cursor over a field in the calendar and click the plus icon that appears in the upper right corner.
  3. Create a new entry in the row details and confirm by closing the window with .
Make a selection in the daily, weekly or monthly overview. Double click to a place in the calendar and the row details will also open. Otherwise, create the entry in the same way as described in the instructions above.
Create calendar entry by double-clicking or using the plus symbol
At the bottom right-hand edge is a Large plus symbol in an orange circle. If you click on it, the row details as well. Otherwise, create the entry in the same way as described in the instructions above.
For this function you need two date columns that can capture clock times.
  1. Create a date column for the start time, turning on the To the minute option.
  2. Create a date column for the end time and turn on the To the minute option.
  3. Open the calendar plugin and select the weekly or daily overview.
  4. Set the two date columns for the calendar in the settings (accessible via the cogwheel icon ).
  5. In the calendar, click on the time you want the appointment to start, hold down the mouse button and drag the box open to the time you want the appointment to end.
Create new calendar entries in the calendar plugin
You can conveniently drag and drop the created dates in the calendar plugin. This will automatically change the corresponding entries in the date columns of your table. This function is available for the monthly, weekly and daily overview.
