To use a common dataset in another base, you can import the corresponding table view of the common dataset into the desired base. To do this, create a new table in the base with the corresponding data set. You can then work with the data of the common dataset or the table view, including specific filter and sort conditions, in the selected base as well.
Requirements
To be able to create a new table in a base with a common dataset, the base must fulfill one of the following two requirements:
- The base must belong to the group in which the common dataset was created.
- The base must belong to a group with which the common dataset has been shared in advance.
Create a new table with a common dataset
- Open a table that is in a base that meets one of the requirements described above.
- Click the [+] symbol to create a new table.
- Click Import common dataset.
- Select a common dataset.
- The common dataset will then be imported into your base as a new table.
If the import of the common dataset is successful, the following message appears:
Characteristics of tables created with a common dataset
Tables created with a common dataset can be distinguished from other tables by the stack symbol in front of the table name. If you move the mouse pointer over the symbol, a short info text also indicates that the table was created with a common dataset.
Another feature is the character on the icon of the columns that contain data from a common dataset. Table columns that do not contain data from a common dataset therefore do not have this label on the column icon.
Consequences for data processing
The overriding rule you should follow when working with common datasets is that information flows in only one direction. Specifically, this means that changes to common datasets and to tables created with a common dataset flow in only one direction - toward the tables.
If you make changes to a table view that you have published as a common dataset, these changes are also applied to all tables that were created with the corresponding common dataset. The prerequisite for this is a synchronization of the respective tables with the data set, which can be done both automatically and manually .
If, on the other hand, you make changes to the data from the common dataset in a table that you have created with a common dataset, these changes do not affect the structure of the common dataset. The changes then apply exclusively to your table and will be overwritten again the next time you synchronize with the data set.
What remains in your table during synchronization, however, are changed column names. You can therefore rename the columns of the common dataset in your table as you wish.
