If at some point you no longer need the common datasets you have created, you can easily delete them from the home page at any time.
Deleting a common dataset
  1. Open the home page of SeaTable.
  2. Click on the Common dataset tab.
  3. Select the common dataset you want to delete.
  4. Click the three dots and then click Delete.
  5. Confirm the process once again with Delete.
Delete a common dataset.
  • For any tables that use data from the deleted common dataset, there is no longer a synchronization option.
  • However, the data of the common dataset, which are located in the corresponding tables to date, are retained.
