SeaTable knows the popular keyboard shortcuts Ctrl +C and Ctrl +V for copying and pasting data. This works both with data you want to copy within SeaTable and with data you want to paste into SeaTable.
Copy and paste data
In a text editor or spreadsheet, select the values that you want to copy into SeaTable. Copy the values with Ctrl +C and switch to a SeaTable table. Select a cell there and insert the values with Ctrl +V one.
It should be noted that copy-and-paste will not work if the formats of the copied data do not match those of the column type of the cells to be pasted.
SeaTable even supports you to the point of adding additional columns when needed.
Duplicate a row or column
Sometimes it’s faster to duplicate an entire row or column. Here you can learn how to do that:
Professional tip
To select an entire column, click on the empty area next to the name of the respective column in the table header. This way, the entire column is selected with one click.
