Once you use the SeaTable app in n8n, you need to allow n8n to access one of your bases. To do this, you create an API token in SeaTable and use it in n8n. This help article shows you what to look out for.
n8n requires registration
Once you use SeaTable as a trigger or as an action in one of your workflows, you need to tell n8n which SeaTable system and base to use. Once you select SeaTable as part of your workflow, you will be prompted to connect to SeaTable.
