You would normally create new rows in the table view. However, in the Gallery plugin, you also have this option. The newly created row will be displayed in the gallery as an album and will be added to the table below all other rows .
Adding a row in the gallery
- Open the gallery plugin.
- Click on the purple circle with the plus symbol.
- A new window opens. Create a new record in the row details and maintain the desired information and images.
- The changes are automatically saved when you close the window with .
